Electrogear, go the way you think is best because it is the best in your circumstances. You are obviously a professional by your attitude. You want solar later, so the thermal store is the best option. Unvented cylinder store high pressure water in a house and need G3 to fit and G3 to service, which costs. You still have the explosion potential. Have the radiators off the thermal store as well via a coil. The ignorance on thermal stores by "professionals" on this forum is apparent. Quite unbelievable. If you have a thermal store with the water in the cylinder not running through the rads sludge does not occur. Sludge only happens when the ferrous from the rads dump the magnetite into the store. Standing losses on unvented cylinders and thermal stores are about the same.
The best way is to have a thermals store cylinder with the following:
- Vented with maybe a header tank just over the cylinder - can be remote in loft.
- Heated directly via the boiler.
- Radiators taken off the store via coil - the rad water is separate to the stored water, hence no sludge.
- A second solar coil.
The stored water will circulate only through the boiler. The only ferrous is the pump, This can be a brass pump and then eliminate all ferrous in boiler and store. The so-called "professionals " think all stores create sludge. Just the odd 1 litre of X-100 needs to be poured into the store every 3 to 4 years just to be sure.
The rad circuit can have a sealed system kit fitted with its own pressure vessel to prevent air ingress. Have the rad circuit fed by a Smart pump. Then TRVs on all rads. If another zone is needed then add a pump with check valve on each circuit.
The solar coil can be connected later.
The boiler can be very big giving a super quick recovery. For e.g., if you get a cheap deal on 50kW go for it, as long as the flow and return pipe sizes are OK. Your gas meter is capable of 62 kW. The bigger the boiler the smaller the store and the lower the standing losses. A thermal store cares not a jot what size the boiler is. Put a large boiler on a small rad circuit and you have boiler trouble. The same with a small coil in an unvented or vented cylinder. The thermal store is a fantastic buffer as all aspects operate independently. The boiler will always be running at its most efficient with full flow through its heat exchanger. It heats up the cylinder in one long efficient burn. Boilers really do last when only heating thermal stores being in the ideal hydronic environment. They rarely cycle and two simple anti-cycle thermostats can be fitted if you want to stop it 100% - I advise to do.
You can also fit a high kW immersion as a backup,
for CH & DHW.
Beware of so called "professionals" who say a Vaillant and unvented cylinder is the only way to go. No doubt these "professionals", who specialise in drains, will come back with ad hominem attacks, with technical substance and experience lacking. Wait and see. It is hilarious to read. Guaranteed to happen.
