Irrelevant. They are not all being rewired.If one makes a wild guess at 20 million domestic electrical installations in the UK, each with around 80 bits of sleeved CPC, my arithmetic says that amounts to around £128 million in 'labour costs'.
Somehow I never thought you would! And although my casual observation for comparison with how things are done elsewhere was dismissed as "irrelevant" by a certain person earlier, I'm sitting in a house full of switches and receptacles which have no sleeving on the ground wires anywhere and I'm not about to lose a second's sleep over it either.However, I am aware of the fact that there are still some remaining ('legacy'!) unsleeved CPCs dotted around my house (I occasionally come across them!), but I have never lost a second's sleep over that!
Join the club.....It's difficult to make any probabilistic statements without being accused of being irresponsible, callous, or worse.
Precisely. Really, the chances of all these things happening at just the split second it would take are tiny, far smaller than the chances of many other things which nobody seems at all concerned about.However, the probability of (a) such an L-CPC short happening (as a result of no sleeving) AND (b) someone managing to touch two things which were, as a consequence, at dangerously different potentials AND (c) that someone being unusually susceptible to electric shock AND (d) that touching to happen within the few tens of milliseconds it would take for the device to operate would surely be as close as makes no difference to the oft-mentioned 'vaninshingly small'!
But many have been rewired since the sleeving requirement was introduced part way into the life of the 14th edition. And gradually, over time, the remaining wiring from the 1960's and earlier is likely to be replaced.Irrelevant. They are not all being rewired.If one makes a wild guess at 20 million domestic electrical installations in the UK, each with around 80 bits of sleeved CPC, my arithmetic says that amounts to around £128 million in 'labour costs'.
Yes, but that's not the point. Nor are all RCDs being fitted 'now' etc. - as you know, the real world just does not work that simply. All one can really do is estimate what would be the total cost of sleeving all CPCs, or installing RCDs in all domestic dwellings, over however long (decades) that takes to achieve, and then see how that 'investment' relates to the resultant number of 'lives saved' (per year, decade, century or whatever!).Irrelevant. They are not all being rewired.If one makes a wild guess at 20 million domestic electrical installations in the UK, each with around 80 bits of sleeved CPC, my arithmetic says that amounts to around £128 million in 'labour costs'.
I essentially agree with that, although everything comes down to money in the end (as witness the fact that you talk of "cheaply" even in your "...rather than (financial terms) ..." clause!). So it's really a question of what one regards as cheap" - and that was the reason I presented some figures to contemplate. If (as I suspect might well be the case with this example), mathematically, the 'cost' could be measured in tens or hundreds of £millions to save one life per year, then someone (thankfully not me!) has to decide, on behalf of 'us' (society), whether that is "cheap" and/or a reasonable/acceptable price to pay for that one saved life per year.Only if one is interested in improvements that show a benefit in financial terms, rather then reducing a risk because, although small, it can easily and cheaply be reduced.
I will stop telling you that there is a difference between assessing what is already installed and installing something new shortly after you stop pretending that there isn't.And everything else being equal, the difference in safety between the socket installed now without earth sleeving and the socket installed 45 years or so ago without it is........ What exactly?
No they don't. They have only to decide if it is reasonable to reduce the already small risk by sleeving the CPC.If (as I suspect might well be the case with this example), mathematically, the 'cost' could be measured in tens or hundreds of £millions to save one life per year, then someone (thankfully not me!) has to decide, on behalf of 'us' (society), whether that is "cheap" and/or a reasonable/acceptable price to pay for that one saved life per year.
In such a trivial case as this, that may be all they would do - but, in general, I do not think that it is reasonable, realistic or necessarily even 'responsible' to consider only the 'benefit' side of a requirement without also considering the 'cost'.stillp said:No they don't. They have only to decide if it is reasonable to reduce the already small risk by sleeving the CPC.
One would have to do one's best to make an assessment on the basis of whatever data, theoretical arguments or even anecdotes could be found. One really cannot assume, 'by default', that anything which is theoretically possible (but may 'never' actually happen in practice) deserves measures to reduce the risk of it happening simply because one has not got enough hard data to properly quantify the risk.How would you go about making a decision on whether or not to reduce a risk in the absence of any historical data?
So no answer to the actual question then, not surprisingly.I will stop telling you that there is a difference between assessing what is already installed and installing something new shortly after you stop pretending that there isn't.And everything else being equal, the difference in safety between the socket installed now without earth sleeving and the socket installed 45 years or so ago without it is........ What exactly?
Given the level of coincident occurences needed, as you outlined above, coupled with the low figures for electrocution per annum overall (not just now, but over a very long period of time) most of which can be attributed to many other things anyway, I'd be willing to hazard a guess that the number is not just less than one per year on average, but could well be nil in total, ever since earths started to be run to sockets and switches. It's really such an unlikely combination of events that, as you say, you probably have more chance of being struck by lightning.it would seem probable that the number of deaths which would result from unsleeved CPCs would be extremely small, probably less than one per year on average.
That's an interesting point. Given the lack of dexterity of some very casual electrical DIYers, coupled with no testing, I'd hazard a further guess that the chances of that happening are quite probably significantly greater than the chances of somebody ever being electrocuted through the extremely unlikely combination of circumstances outlined for a bare earth.One other issue which has not been mentioned is a 'downside' of sleeving CPCs, particularly for DIYers (most of whom will not undertake 'all required testing').
Yes, that's almost certainly true. I thought I might get less criticised if I stuck with the very conservative 'less than one per year' (rather than 'probably never'!!), particularly since that was more than adequate to make my point ....... I'd be willing to hazard a guess that the number is not just less than one per year on average, but could well be nil in total, ever since earths started to be run to sockets and switches.
... and that was my point. I would say that it's all but certain that the 3-4 UK deaths per year due to people being struck by lightning is appreciably greater than the risk of being electrocuted because of the absence of CPC sleeving.It's really such an unlikely combination of events that, as you say, you probably have more chance of being struck by lightning.
I have no idea, but would very much suspect the latter.I've never seen any explanation as to why the sleeving amendment was made - Was it really based upon some desire to guard against the possibility of an extremely tiny risk given evidence of such risk, or did it just "seem like a good idea" at the time?
I agree, but I think it may be a more common problem that you imply. I would probably not regard myself as "very casual electrical DIYer who lacked dexterity" but, as I said, I've certainly done it a few times (that I know of - possibly more!).That's an interesting point. Given the lack of dexterity of some very casual electrical DIYers, coupled with no testing, I'd hazard a further guess that the chances of that happening are quite probably significantly greater than the chances of somebody ever being electrocuted through the extremely unlikely combination of circumstances outlined for a bare earth.
The risk doesn't have to be quantified. When a risk is identified, there is a duty to reduce that risk to as low as reasonably practicable. It is clearly a trivial cost and inconvenience to add sleeving, therefore there is no need to justify its use.One would have to do one's best to make an assessment on the basis of whatever data, theoretical arguments or even anecdotes could be found. One really cannot assume, 'by default', that anything which is theoretically possible (but may 'never' actually happen in practice) deserves measures to reduce the risk of it happening simply because one has not got enough hard data to properly quantify the risk.How would you go about making a decision on whether or not to reduce a risk in the absence of any historical data?
