What is AC does it have a polarity.
27 Jan 2008
Llanfair Caereinion, Nr Welshpool
I know the BS7671 tells us to test polarity and it means test the voltage in respect to earth. But AC changes its polarity in step with the frequency. So this image:-
shows an alternating current zero to max without any change in polarity. But in the main I am sure we would call this DC. However the current is still alternating and if you connected the supply to a transformer it would still transform it although not very well.
So real question is if the polarity refers to positive or negative what word should be used to refer to relationship of the live wires in relation to earth? Polarity seems the wrong word.
Potential might be a better choice of word, since what you're really checking for is which wires are not at earth potential, i.e. they're hazardous.
Looking at BS7671. The only reference to "polarity" is the para relating to making sure that a single pole switch is in the line conductor.
Otherwise it is not mentioned, or defined.
That is as far as my interest goes in this matter….
If you connected that supply to a transformer the large DC component would soon burn out the transformer.
I don't think I'd describe that graph as showing an alternating current. To me, 'alternating' suggests regular change of direction of the current. I suppose a better term for that graph might be 'pulsating DC'.
Mind you, I'm not an electrician, so what do I know?!:D
