- Joined
- 29 May 2016
- Messages
- 9
- Reaction score
- 0
- Country
BOILER: Ideal Isar
AGE: approx 6 yrs old
HISTORY:
New Diverter Valve fitted 5 months ago, due to heating not coming on and new Thermostat/Programmer/Remote Control (herinafter referred to only as "Thermostat") supplied at same time. No major problems overall.... until 2 days ago!
NORMAL CONDITIONS:
Boiler (in kitchen) permanently on 24/7 for hot water; Heating has been off around 3 or 4 wks. 'Thermostat' is located by front door. No individual room or radiator thermostats.
Upon returning from holiday 4 days ago, we felt cold
so put heating on for the evening - it came on and off as it should and was switched "off" the next morning.
Then 2 days ago, I'd been complaining how hot it was and when hubby went to bed
, he quickly re-appeared saying "The heating's on?"
'Thermostat' (by front door) was turned "OFF". Boiler (in kitchen) was showing "L" normal running conditions - it wasn't showing "C" which indicates when heating is on?
I turned all settings on 'Thermostat' to -5degsC (frost setting) and waited for heating to turn off. It continued to pump out tremendous heat, climbing up and up! It soared past our usual room setting of 20degsC! When it reached a very uncomfortable 25degsC
, I had no option but to turn the boiler off!
Around 4hrs later, so hubby would have hot water when he got up, I changed batteries in 'Thermostat' and turned boiler back on - it resulted in a very hot uncomfortable night with heating belching out heat!
We had no option but to turn off the boiler completely - no hot water - but at least we're not being cooked alive!
Could it be 'Thermostat/Programmer/Remote Control' rather than Boiler
Please ask further questions if necessary in order to help ascertain the problem. Any help would be greatly appreciated and even contact from a local Heating Engineer in Birmingham, B37 area.
Regards,
Bev
HISTORY:
NORMAL CONDITIONS:
Regards,
Bev
