- Joined
- 27 Jan 2008
- Messages
- 29,210
- Reaction score
- 3,581
- Location
- Country
It says my Energemie MiHome Socket is ITTT so I wonder can I write a computer program to tell it when to turn on and off?
It has three on/off slots per day, however I need four, I started with a socket with remote, seemed good, but too easy to think it was on when in fact it was off, so swapped to a time switch, this turned the socket on and off OK, however if I want the leave the house other than the pre-programmed times the alarm powered from the socket would go off, so then tried the MiHome socket which combined timer and remote control, so I can switch off leave house and switch back on again, plus set so it's off at the times when mothers carers are due.
This was spot on until today, when visits were upped from three to four, and the MiHome socket has a maximum of three on/off commands. So looking for a way to get an extra on/off command. So maybe I can get the computer to auto switch off the socket for that extra slot?
Maybe I can get battery backed time switch to get extra slot, but it would be better if I can set the PC to turn it off that extra time.
