To access it you need to remove main cover which exposes the combustion area. Its a one piece case.
Cheers Dan. I already removed the cover !!!!
Which sounds a little bit on the high side to me
On the grounds that, it sounds expensive ? On what grounds do you ask ?
I'll be expecting my Blue Peter badge by the way. I'll send you yours, when you can tell me how to remove the cover of a Nautel 10kW MF TX without killing yourself![]()
Easy- switch it off first![]()
