- Joined
- 13 Sep 2015
- Messages
- 262
- Reaction score
- 158
- Country
Hi All,
SUMMARY: Can I use a copper compression fitting on the expansion discharge pipe of a gas boiler?
I have a a Vaillant system boiler, about 5 years old. I need to change the route the expansion relief/discharge pipe takes.
I know that the run must be in continuous copper pipe, the end of the pipe must be visible, shortest run with slope away from boiler and it must terminate in a safe place where people can't be scalded. I'll be going straight through the wall the boiler is mounted on and terminating outside with the usual 180 degree bend back into the wall.
Is there any reason why I can't use a compression fitting to make the join between the vertical pipe connected to the boiler and the horizontal run? I know it is normal to solder, but it's a bit cramped in there and I don't fancy wielding my blow torch so close to the boiler ... I assume this is ok as the final fitting to the boiler itself is just supplied as a 15mm compression?
Many thanks!
Many thanks!
