- Joined
- 27 Jan 2008
- Messages
- 28,481
- Reaction score
- 3,459
- Location
- Country
All I can say is how my mother UFH has worked, fitted under sculptured tiles in her wet room. Idea was to dry the floor and make it warm under her foot, plus heat the room together with a towel rail.
On switch on it takes an hour to get even warm, there is wood below the heating mat then insulation so theory heat should go up. On turning on the shower the floor is cooled in seconds, and it takes another hour to warm up again, the sculptured tiles were also a mistake they hold the water so take longer to dry.
So from experience it does not heat the room even when left on 24/7 it is not enough to heat room it needs the heat from towel rail.
It takes two hours before you can walk on the floor and actually feel the floor is warm.
The thermostat was renewed many times, they don't seem to last long, and the pocket for the floor sensor had too sharp of a curve and the sensor stuck and broke off. The heat is so small I don't now bother with underfloor sensor it is simple to dry off floor after a shower, it is not used to heat the floor, the first one was damaged by builder and all tiles had to be removed, lucky builder used out of date tile cement so they came up easy.
It is really a white elephant, I will put it on after a shower to dry floor, but if honest it would be just as easy to use a mop. For floor to be warm for mother, I have to switch on as we go to bed so it is warm in the morning, and fan needs to be off and door closed.
Oh and yes used an insulation tester with 500 volt to test insulation plus RCD protection I would not want to walk on tiles with heaters underneath without using a proper insulation tester.
