- Joined
- 27 Jan 2008
- Messages
- 28,904
- Reaction score
- 3,536
- Location
- Country
House from Wiser web site, bottom right room has a eTRV and a room thermostat, I just can't work out why with a hub and eTRV in every room one needs a thermostat? I thought idea is the eTRV tells hub if satisfied or not and the hub either tells the boiler to switch on and off or with opentherm how much heat is required.
So where does the room thermostat come into all of this? I have looked at Hive and Nest as well, and just can't see what they do other than act as a hub to read IFTTT commands from the eTRV. Although with opentherm it needs some computer to work out heat output levels, with the non opentherm boiler all it needs is a simple relay. If any eTRV has the target temperature above current temperature then run boiler, if all eTRV current temperatures are equal to or above target then switch boiler off.
What am I missing?
