Hi all, I hope someone can help me. I've moved in to a property and I'm trying to complete jobs myself and learning along the way.
I want to fit an external security light, there is mains wiring present from a previous light, I intended on using a junction box and fitting the new light to it in this way.
The grey mains cord is made up of an exposed copper wire, a blue neutral wire and a brown live wire - the brown and blue were connected to the fuse in the picture which then ran into the previous light.
The issue I've had is the fuse will not fit into the junction box I've bought, on the previous light, where the cable met the light the screw fitting housed the fuse which was then attached to the light.
How do I connect this light to this cable? Is there another way / should I use a different junction box?
Also, why was the previous light wired with just a neutral and live where as the new light also has an earth? (I assume the new light could have been wired straight to a 3 pin plug?)
Please see attached pictures, any help is much appreciated, thankyou for your time.
Attached is a picture of the light itself, the fuse where the mains cable was fitted to and the junction box I have.
