Do soakaway crates allow soakaway close to building?
22 Jan 2012
UK
I've been following a Planning Application near to me, and where the authorities have raised concerns about the rainwater soakaway being too close to the house due to the small garden, the designer has replied they will use soakaway crates to mitigate this.
Is this a valid option? If so it may appeal to me, as I would like to drain a driveway into a piece of garden 2.5m from our home.
We live on basically a sand dune.
Thanks!
Tim
Crates are no different to stone ones, they just hold more water.
Do BC take in to account the soil type, or is it a fairly standard 5m?
As I live on sand, and i would be fitting one purely to drain the 26 square metre driveway, so would probably just do it without permission tbh 2.5m away from the house!
So BC aren’t involved yet? I’d keep it that way.....
For me, no. It's just changing a gravel drive to a paved drive, and ensuring my surface water doesn't end up on the highway. No intention of telling them.
Was also really just wondering if the architects argument for the house development around the corner was accurate, seems its BS.
Thanks all for the input :)
Get it in the sewer ;)
That would involve an expensive trench into the road! The sewer is about 5m to the side, and on a lower ground level.
All the rainwater downpipes go direct into the sewer, presumably from when the house was built in the 50's and there was no mains sewer connection!
Old soakaways are often not 5 metres away from rear of house.
What you dont want is ground swelling. I should imagine though that sand has a low swelling factor and a high percolation rate.
Crates can hold a lot of water, over 90% compared to a hardcore soakaway that prob less than 50% new and can fully silt up in time.
I guess you dont want a permeable driveway or linear drain
http://www.pavingexpert.com/drain14.htm
Tap into them as they go down your driveway.
