Hi there
I wondered if anyone could give me some advice on replacing my radiators? I have lived in a Victorian terrace for three years now and during winter the heating struggles to get the house warmer than 18C when it is cold, even when the boiler is on permanently.
Basically I have realised that the radiators are too small to heat the house. Using a webpage I would estimate that the maximum output is around 6kW (If i have calculated correctly).
I've had couple of people round to quote for installing some bigger ones but one of the plumbers pointed out that my pipes all appear to 15 mm rather than 22mm. He suggested that I would need a whole new 22mm mains type system upstairs which could then drop down to heat downstairs because it is difficult to lift the floor because of tiles and laminate. The other plumber didn't mention this at all.
I was planning just to replace some of the downstairs rads and take up the output to around 10kW I think. But now I don't know whether this will work? I've read a few things which says that the pipes might get worn out etc. The boiler is an Ecotec Pro28. Any advice would be gratefully received. Thanks
