- Joined
- 27 Jul 2018
- Messages
- 8
- Reaction score
- 0
- Country
We have a Ravenheat CSI Primary AAA condensing boiler used for HEAT ONLY.
Intermittent but persistant problem that has started in the last 4/5 days. shortcycles on and off for up to 35 secs per cycle for 5 mins or so, then cuts off showing red light on boiler.
It's running 9 rads at a low temperature with rad stats and a room stat. all of which are functioning fine.
The intermittent element is that it will stay on for hours and heat perfectly when it decides to stay on! it has done so eventually last night despite resetting numerous times throughout the day and each time shutting off with the red light.
Turned it off with the room stat last night and boiler has red light this morning! however after a reset is working fine now so far!
It has no filling loop or pressure gauge as it is a system boiler heating rads only. The condensate pipe is indoors so won't have frozen in the cold snap. There doesn't appear to be a frost stat on the boiler either.
Any helpful suggestions welcome with regard to identifying the fault. Thanks!
