Rossi E-Cat cold fusion to solve world energy problems
It appears the authorities in the USA are looking into Rossi's supporter This posted in a forum concerned with alternative power sources, fact or fiction
Der oberste Fachgutachter und Hauptvermarkter des AuKW, Sterling D. Allan, hat Besuch vom FBI bekommen. Leider haben sie versäumt, ihn als Zeugen im Fall Rosch zu befragen.
http://freeenergyscams.com/sterling...ng-investigated-by-the-fbi-and-local-sheriff/
(( The top referees and main marketer of AuKW , Sterling D. Allan , has received a visit from the FBI . Unfortunately, they have failed to interview him as a witness in the case Rosch ))
It does seem that Sterling D. Allen has several connections with dubious activity, investments and even suggestions of anti social behaviour. He and Rossi are suited to each other.
I don't mind people believing in fairies, perpetual motion or kitchen-table cold fusion, but I am very suspicious of anyone who circulates anonymous and unsubstantiated marketing flannel that might draw in credulous people and their money.
Martin Fleischmann Memorial Project have made a breakthrough in their replication:
Published their LENR Recipe for All to use and experiment:
The Cookbook is in the signal…
Prepare thoroughly (Ni + LiAlH4 + Li)
1. Bake Ni
2. Reduce Ni
3. Hydrogenate Ni
4. Mix: Ni + LiAlH4 + Li
5. Bake and vac reactor, add Nickel, vac warm, add H2, Vac
6. Heat to above Mossbauer determined Ni Debye (say 135C), pressure regulated to approx 1bar abs.
7. Hold, pressure regulated to approx 1bar abs.
8. Heat slowly to as close to Ni Curie as comfortable (Say 340C), pressure regulated to approx 1bar abs.
9. Hold, pressure regulated to approx 1bar abs.
10. Slowly lower temp to above highest known Ni Debye (Say 220C), pressure regulated to approx 1bar abs.
11. Hold, pressure regulated to approx 1bar abs.
12. Go as fast as possible through Ni Curie
13. Hold, pressure regulated to approx 0.5bar abs.
14. Cycle through 500C internal, pressure regulated to approx 0.5bar abs.
15. Hold, pressure regulated to approx 0.5bar abs.
16. Raise internal temperature to over 1200, pressure regulated to approx 0.5bar abs.
17. Drop to around 1000 and hold, pressure regulated to approx 0.5bar abs.
18. Raise internal temperature to near boiling point of Lithium
1h Thermal > x/β- emissions > Pb > IR/THz > 5h (SSM)
where ‘>’ means ‘leads to’
The End of the Carbon Age is Nigh
Thank you to all those that helped us
http://www.quantumheat.org/index.php/en/
Go on them WarmSok.
Do some cooking and heat your house.
Come back and give us the results.
That is assuming you and your house / laboratory survive item 18
1. Bake Ni
2. Reduce Ni
3. Hydrogenate Ni
This tripe is just using scientific language to convince those that don't understand it, that it might just work. "Why, that's so crazy it might just work Batman!". Case in point - references to "pressure regulated to approx 1bar abs" .. well 1 Bar absolute is atmospheric pressure. If you were a scientific writer, why go out of your way to add this nothing statement? On the other hand if you were a fiction writer.... Other references to pressures less than 1 bar are a vacuum - not unachievable by any means, but clearly misunderstood by the author of this fiction.
Nozzle
Online demo > www.ecatskdemo.com
from https://animpossibleinvention.com/blog/ :
"The moment of truth is getting close with launch on January 31st
On January 31, 2019, inventor and entrepreneur Andrea Rossi will hold an online presentation on the commercial launch of his heating device, the E-Cat. Thereby, the moment of truth is approaching for the carbon free, clean, abundant, cheap, and compact energy source that could potentially replace coal, oil, gas, and nuclear, and also solve the global climate crisis."
keep up to date here : https://e-catworld.com/
You see, socks, the way evidence works, is that if you make an assertion, you have to provide evidence to support it.
The rest of the world is not required to produce evidence to prove you wrong.
Nobody is obliged to believe you if you make the unsupported claim that the moon is made of spam, or the world was created by a pink unicorn.
"What is asserted without evidence can be dismissed without evidence"
You mean like creationism or brexit, where everyone dreams up their own "evidence"scientific or otherwise.
I'm torn between asking you to explain what you mean by that, (with "explain" involving concepts such as logic and intelligence and reasoning) and just ignoring it in the grounds that ever expecting you to do anything involving logic and intelligence and reasoning is like expecting to win £100M in the lottery without buying a ticket.
Keep up man,,,referring to your yarping on about how you are the king of quote,requote and affiliated bolox on this site,yet you requote with no additional response,schoolboy error.
It doesn't seem to matter how spectacularly bad you have been at this in the past, you can always be relied on to keep on getting even worse.
