Mixer Basin Tap?
jcp
7 Aug 2006
Oxfordshire
Hi
I need to replace a bathroom basin and 2-taps, and the family want a 'modern' mixer-tap. The old plumbing has mains cold water and loft pressure hot water. Is there a suitable pressure reducing valve I could put on the cold, or do I need to provide a loft pressure cold supply? And, isn't the mains pressure cold to provide drinking water quality at the basin?
Any advice welcome.
Simply fit full bore isolating valves and if needed close the cold by as much as you want so to reduce the pressure.
Mind you, mixer taps come in 2 forms, suitable for high pressure only and suitable for low pressure.
You need a low pressure.
Closing down will only reduce flow, not pressure. You will need to fit a check valve if fitting onto unbalanced supplies, failing that take a feed from loft.
It's pressure that can be the issue not flow when mixing mains with gravity, in a mix in the body monobloc, turning the ISO valve can sometimes work but it just drops the flow not pressure. It really depends on how big the difference between each is, whether using the ISO works or not, that and they tend to get noisy when using them to restrict the flow.
The ideal is to use a dual flow basin mixer/mono tap, then the water doesn't mix in the body where balanced pressure is important, it mixes at the end of the spout. Not a huge selection to choose from though.
  • Thanks
Reactions: CBW
https://www.bes.co.uk/flow-regulato...Xpvm7yMvwNsVs2cugBpfnVSorf0J0mrQaAlqDEALw_wcB
Thanks all for your comments, but I was specifically asking about a pressure reducing valve, not half closing an isolating valve.
I have used a half closed Iso-valve to roughly balance flow to a bridge tap (separate internal pipes until end of spout) in the kitchen. This too has mains pressure cold supply and loft pressure hot. However, each feed of a bridge tap has its own this tap valve, so flow rates can be adjusted independently to get a balance. I'm not sure this is true of a "monoblock" type tap - would I have to adjust the single lever side to side when I move it up and down to adjust the combined flow?
  • Thanks
Reactions: CBW
it's called a dual flow tap, a bridge tap is something different.
yes, to do it more accurately, you need either a pressure reducing valve
both apply pressure to a diaphagm
or a pressure equalising valve.
The trouble with those is that the pressure of both will have to be dropped to the lower value so the flow out the tap may be reduced by a fair amount.
  • Thanks
Reactions: CBW
As Madrab has said, a pressure equalizing valve will reduce the pressure of both hot and cold to (at best) the lower of the two, in your case almost certainly the hot. If the basin is on the floor below the loft cold water storage cistern, the difference in height between the base of the CWSC and the tap determines the available pressure head. If this is the case you'd be lucky to get 0.2 bar of pressure, and many modern mixer taps just won't work on such a low pressure. Make sure you know the minimum pressure rating of any tap that you propose buying, preferably with its flow rate in litres per minute at that minimum pressure.
...I need to replace a bathroom basin and 2-taps, and the family want a 'modern' mixer-tap. .....
...Any advice welcome.
Tell them they can't have one.
