Hi All,
After a bit of advice here, I am a tado user and have had the smart radiator valves and smart thermostat for approx 2 years..
The heating system is an S plan system with HW tank in the loft and a Potterton Netaheat 80E which is old but works ok.
The system was previously controlled by a sunvic timer / programmer. when I installed the smart thermostat it replaced my honeywell room stat, the sunvic timer was set to constant ' ON' for CH and HW was managed by this timer on a schedule.
Slowly I added in tado rad stats for the TRV's and the system was working OK.
Now I have added in a extension kit as I also want to control the hot water with tado ( which works) but also herein lies the issue. It would appear ( with constant back and forth from Tado) that a tado rad stat cannot tell the extension kit AND the smart thermostat to demand for heat.
So essentially what happens is bedroom 1 calls for heat, this goes to the extension kit, and then tries to run it to the boiler ( but the wired smart thermostat is in the circuit) this relay ( in the smart thermostat) does not make the connection and the boiler doesn't fire. I've spoken at length to tado and they said I need to consult with an electrician, in fact their response was the standard cut & paste
From the information you have provided us with, we understand that you would like to add Smart Radiator Thermostats to your current heating system, and that this heating system has separate zones controlled by zone valves (often referred to as motorized or 2-port valves).
Currently the installation of Smart Radiator Thermostats on multi-zone homes is possible if your heating system consists of either:
a) zone valves which are controlled by wired thermostats that send a call for heat directly to the boiler, or
b) where there are only two zones, one controlled by an Extension Kit, and the other wired directly to a Smart Thermostat.
Our Smart Radiator Thermostats are able to call for heat from the boiler because it not only opens the radiator valve, but also asks the Smart Thermostat or the Extension Kit to send a demand for heat to the boiler.
It is not possible, however, for the Smart Radiator Thermostat to ask the Smart Thermostat to ask the Extension Kit to call for heat.
Therefore, if your heating system has any other configuration (e.g. more than one wireless thermostat, or none of the thermostats are able to call for heat without a timer or programmer set to "on"), then you have 2 options:
My question is, if the extension kit is now calling for the demand from the other devices ( as this has become the primary ' brain' and is switching the heating circuit on and off, is it just a case of the connection that the smart thermostat was making, just needs to be bridged?
More specifically NO & COM ( or rewired at the junction box, but for arguments sake)
This would effectively make the smart thermostat wireless ( as it has it's own internal battery) and send the signal for demand from the Extension kit to the 2 port valve for CH and fire the boiler accordingly.
Hope this makes sense!
Thanks in advance.
- We can configure the Smart Radiator Thermostats so that they simply run a schedule when someone is at home. They will not be able to call for heat from the boiler, but only open/close the radiator.
- You can discuss with an electrician to have your heating system rewired so that it functions as either system a) or b) mentioned above
Thanks in advance.
