I have a 20 year old boiler. I last had a servicing done 5 years ago.
It was high time so I recently had servicing done by a Gas safe engineer. He capped it and marked as Dangerous as :
-the Flue pipe going outside does not have enough empty space around it
-the hole for the flue-pipe is not sealed on the outside
-air integrity failed
-there's a fat metal block in the middle inside the boiler that is meant to get hot as soon as heating is switched on. Mine wasn't doing it
-something about CO being emitted ( guy used a meter )
Moreover, he said the boiler is operating at 50% and quoted some expected and actual figure discrepancy. He recommended the boiler be changed asap. He did also mention that changing the block would cost £300 total but other parts may break down few months later.
I have had two other engineers have a look at it and no one wants to touch the boiler. Everyone suggested replacing the boiler with a new one.
I had one tell me today that if you resolve the flue space issue, the boiler will start working again and does not need to be replaced.
Does a boiler even work like a car ? You fix the parts , do an MOT and the boiler starts working again ?
What's with the cap ? Can I not remove it and get work done down the line ?
Furthermore, it seems the pipes going into the boiler are 15mm but the main one from the meter is 22mm. So, some cowboy years ago must have been responsible for this. All new boilers seem to require 22mm and this would involve digging floors in my case. The only 15mmm I can see is Ideal independent but I have never heard of this brand before!
Suggestions please.
Suggestions please.
