- Joined
- 22 Aug 2006
- Messages
- 7,098
- Reaction score
- 1,209
- Country
All of that apart from bleeding the radiators could easily be done well within 20 minutes. A gas tightness test is not part of a service, (or even a landlords's gas safety check).
He might have seen the flue on his way into the house, or out of a window., or relied on the FGA numbers which would have indicated a significant fault.. That misses out bits of ivy getting near it, it's true.
Opening the boiler to look inside - couple of screws and a few seconds' look. Look at the seals, do the screws up again.
FLue and vent to GSIUR - a glance. That boiler, there would be nothing to check, by design.
He does not necessarily need to look at the meter.
The GSIUR requirement is to measure the gas consumption OR working pressure, iirc. Not both. I don't know offhand if that boiler tells you the working pressure ( "service" combination of button presses may reveal all sorts.)
Absolutely you would not expect igniters or any other random parts to be routinely changed.
Temperature sensors typically last the whole life of the boiler. They do not wear out.
Condensate traps are usually visible clearly. Not sure on that boiler. If you can see the sump is clear - at a glance - nothing to do.
There is no HW cylinder.
If the boiler pressure is ok, no action to be taken.
Someone who knows the task can clear most of it with educated LOOKING.
BG and others have shown that things like unwarranted dismantling "to clean" decrease reliability. They tend to strain clips, promote leaks, etc.
Your statement is not appropriate, to the extent that it would cover more than a service. You might like a check on the water composition, but it's not a requirement.
Sorry Harry, but you're 98% wrong. Things have changed since your parents' back boiler.
The checks are simple, but not meaningless to someone who understands them.
It's a bit like looking at an ECG. Even I could spot major problems. A doctor could tell you 10 times more or see anything needing investigation. In about 10 seconds.
If you raised hell at BG they'd rip you to bits, in fewer words than I've used.
You check if something looks like it's going wrong. If not, no action.The point of a service, is to prevent breakdowns, and help prolong the service life of your system.
