Tank floating valve
10 Aug 2017
Hi
so had the floating valve replaced in my loft tank, the plastic spout thing that the water shoots into the tank out of is screwed into the assembly but it’s spins freely when the pressure of the water shoots through it
I’ve tried to tighten it but when it reaches its tight position it’s pressing against the wall of the tank
I’ve checked the one in the radiator header tank and the spout is firmly in place
should I be concerned ?
Yes, as it might come off and water will hit the tank lid and could overflow the outside of the tank, causing water damage to the ceiling below.
Andy
When it spins it can’t fully rotate as it hits the wall of the tank
Undo the plastic nuts either side of the tank and move the fitting in, this should allow more room to rotate the plastic spout.
Andy
I’m able to rotate it fully if I apply a bit of force but when it’s tight it’s pressed against the tank, I’ve removed it and put it back on thinking that it will end up in a different location when it’s tight but at its tightest point it’s always pressed against the tank
Ok, as long as it is tight and in the correct position. It doesn't have to over tightened.
Andy
Ok so the plastic tap spins freely in both directions as shown in photo, if u turn the tap to tighten it it tightens but the tap is then pressed against the wall of the tank
That part of the fitting shouldn't tighten, it should be able to rotate freely inside the fitting, it's just the flow diverter. They're usually just push clipped into the valve.
Ok so my mate had a spare plastic spout, looks exactly the same so screwed that one on and it was a much firmer fit, felt firmer when screwing it on so it’s now firmly in position
Update
Now there’s a slow drip from from the spout, it was fine for a while now recently this has started.
should I be concerned? Is it because the tank is massive and takes ages to fill?
Also can someone tell me what uses the cold water tank, I’m guessing the hot water taps and Emerson heater tank? Anything else that could be pulling from the tank without me knowing causing the water level to slowly lower?
cheers
If you pull the float arm up does it stop dripping? You may have a cold tap and toilet in an upstairs bathroom that is fed from the cistern as well as the hot water cylinder.
Yes and when I manually push the ballcock down and let water in it doesn’t drip, seems when we are using taps and the water level drops it’s struggling to get back to level.
I guess the dripping will be constant as when the valve gets close to closed the water level will lower again with normal use of taps and what not.
Sod it, can only hear the dripping if I stand and listen for it.
Replace it.Accident waiting to happen.
Replace it before you are standing looking at your ceiling down.
