Removing stump close to fence corner
18 Jul 2019
This morning I started digging around the stump to find as many roots as possible. I was going to find all the roots I could, cut them and have a go at ripping the stump out.
Then I realised maybe when the roots wither it'll cause movement and damage to the fencing.
I bounced the idea with some family members and they're talking about a tree grinder, which sounds like it'll do a lot of the back breaking work for me. Although I'll have to clear out all the stones I think.
But I wanted to discuss the possibility of damage/movement after removing. Its position is in the corner of our garden and very close to the fence. What are your thoughts?
A grinder is OTT for that
You basically just have to start digging. If you use a small spade, trowel and crowbar, you'll get there.
I had an awkward one where a tree had grown into buried rubble and had to resort to nightly blasts with a pressure washer after picking out roots and bricks. Once I had spent an hour removing stuff freed by the water, I pressure washed soil away and left it 24 hours til the next day's extraction
I wouldn't resort to water until you've removed as much as you can around the trunk.
DO NOT saw away at the trunk, you need it for leverage.
A mattock is ideal for this, and maybe a pruning saw
unless you have a plan for that corner, you could just try and cut the stump off just below the surface and cover it. It will rot away over time and I seriously doubt it will affect the fence, with it being a corner post I doubt is doing much work, even if you cut the post off at the bottom I doubt the fence would fall over.
I would probably try and dig it out, I doubt the roots will be that extensive on it, you need something to slice through the roots, I have a sharpened spade blade taht its into a heavy metal bar that is wonderful for jobs like that
Nice one thanks for the insight Tigercubrider. I do have a mattock and pruning saw. Both so far have proven effective.
unless you have a plan for that corner, I would just try and cut the stump off just below the surface and cover it. It will rot away over time and I seriously doubt it will affect the fence, with it being a corner post I doubt is doing much work, even if you cut the post off at the bottom I doubt the fence would fall over.
Yeah that's a decent idea. Definitely umming and ahh-ing on that one.
Thats the tool you need or even an old axe which has the blade inline with the shaft If you use a mattock which has the blade at right angle to the shaft the chances are the edge will hit part of the stump deflecting it into the fence
I find mattocks are a struggle to put to good use
