How to stop shed door slamming
21 Dec 2010
Surrey
The kids keep leaving the shed door open when getting their bikes out, and the wind can slam it shut with enough force to take off some fingers or break a limb.
What I want is something that will force it to close at a slow, controlled pace, but will also allow the door to stay open. Ideally at 180 degrees, where it could be held open with a cabin hook, but less would be OK.
The closest thing I can think of is these door closers with a 'hold open arm', however they seem to all fit on the opening side of the door, which on my shed would be exposed to the elements.
Can anyone think of a product that fits my needs?
Pete
On my small doors into the garage and the workshop, I have a simple gadget, with a sliding steel arm and a latch. If I fully open the door, it latches and stays open until I pull a release cord. On my garden hut door, I have a steel plate and on the hut wall it would open against, I have a repurposed large hard disk magnet. Open the door and it stays open wide, retained by the magnet.
I live at a high spot, so it is sometimes quite windy.
Have a line over a pulley attached to garage door, other end has a length of chain to match door weight which falls into a piece of downpipe to keep action smooth .
Closes the door even in wind without slamming and use a bicycle kick stand screwed to bottom of door to hold open when required , can be set or released with the foot .
[Edited] We're back to the bricks again, Foxhole, just this time one has some string and a pulley artached whilst the other just holds the door open..
Thanks all, I've got with a door closer as in my original post - turns out you can use it on the inside of the door just by mounting it upside down.
Door closers can be installed on the door, on the wall or even at the top.of the door casing with the arm at the bottom (requires a bracket which may or may not be in the kit). AFAIK there is no "upside down", at least on modern closers which have a square drive on both edges to allow left and right fitting
