- Joined
- 17 May 2012
- Messages
- 11,390
- Reaction score
- 1,011
- Country
I am planning to rip out existing shower room and put back a bath. Currently there is hot and cold (from water tank) feeding a shower. We have 0.1 bar pressure on the hot. The new shower is fine like this, but hot water tank is not that big, and if we all (4) have shower at the same time we run out of hot water.
As this will be a bath mainly, and emergency shower, I was thinking better to have an electric shower, that way we don't need to worry so much about running out of hot water.
The room currently has an electric heater on its own circuit, which I am planning to remove once the room is insulated and new rad installed.
Anyway, I just looked at electric showers and was shocked (no pun intended!) that they were so cheap - and there's one in Wickes now reduced to £30. This seems really good value and a cheap way to have a back-up shower.
Thoughts? And could a sensible plumber install the electric shower, or do we need to get an electrician to wire it up? And ... crazy idea, maybe, are there electric showers that sit on the other side of the wall, with just controls on the bathroom? Because I plan to box in the area on the other side - the cold pipe can run down here too, and maybe if the shower was in a cupboard there, that would keep things looking tidy, and maybe make the electrics easier too.
old shower, currently tool storage
heater in its own circuit
other side of bathroom, will box in (also thinking of removing the chimney stack ..,)
