I have this Vaillant in a pressurised system and have the VRC 470f controller. Heating works perfectly on the timer as does the hot water. However, I cannot have hot water and central heating on at the same time. Normally not a problem as it is rare for us to need both on. However, at the moment my wife is recovering from an op and needs more heating! If the heating is switched on before the hot water is due to come on via the timer then the hot water does not heat up. Conversely, if the hot water is already on the rad will not heat up. My previous systems in other houses could always do both. Is this a fault, a setting issue or a feature?
