I'm cleaning and re painting my old vice. I got it from a car boot many years ago. It is working but stiff and rusting and one of the jaws is loose.
I suspect the bolts holding the jaws are imperial. They go through the casting and are tapped into the jaws. One side used a 14mm spanner and the other side an 11mm spanner. The clearance holes are somewhere between 7mm and 8mm.
Any idea what size the bolts are likely to be? Both are threaded. I'm wondering whether to try and find replacements or to replace with M8.
If I do go for M8 how hard will it be to expand the clearance holes in the cast steel, and re tap the threads in the jaws? 9mm for the clearance hole and 8mm for the tapping? I only have a carbon steel tap.
