Yet your benchmark pic is blank ?
It says 'OR'. Suggesting 'Burner operating pressure' OR 'Burner input pressure'. Later item is indicated to be 20mbar for both HW and CH.
System boiler, so unless its been fitted with vaillant controls which I imagine its not, then you need the higher flow temp for DHW production. Had it had vaillant controls then you could select independent flow temps for heating and then higher one for DHW (or even lower for DHW and weekly legionella cycle)
ABV not required by this boiler, so wont have any real effect on it.
So no point in this boiler being condensing?
Is that not a gross install error and against best practice?
If not, is it not also "a good idea" to get proper controls so that it does condensing?
Harry it does not say "burner input pressure" appliance inlet working pressure and burner pressures are completely differentIt says 'OR'. Suggesting 'Burner operating pressure' OR 'Burner input pressure'. Later item is indicated to be 20mbar for both HW and CH.
In a previous life as a warranty engineer I mainly visited new (<5 year old) systems, and can easily say 95% were left set at fixed 75⁰c CH flow.
But its not.Must also be law that they are installed with appropriate controls to ensure they operate in condensing mode
It's law in the UK to only sell condensing boilers no?
Must also be law that they are installed with appropriate controls to ensure they operate in condensing mode else what is the point? Lol.
- Yes, only condensing boilers allowed to be sold
- Boiler plus is the minimum standard along with boiler interlock - not sure if regulated that well, if at all
- Best will in the world, could be setup correctly, customer not happy as rads don’t make them have red hands after touching, become google warriors, or ask on forums, like DIYnot.com how to increase their temperatures etc.
I just meant that if he was replacing like for like, he might argue that as the previous set-up was OK, and the gas flow hadn't changed, there was no need to check the gas pipe.It doesn't.
Condensing boilers are still more efficient than their Std eff counterparts, even when there not condensing. Enough that there was a notable drop in domestic gas use after the introduction of condensing only boilers. But that could be a further 5-10% had they legislated that they must be on lower temperature systems
Silly question, why would you think that?
