The flooring guy came yesterday, broke a bit of the polystyrene off and confirmed it is Jablite (white balls compressed together by the looks of it). He suggested if concerned it may be worth just drilling a couple small holes in the chip board floor to see if runs through the property, the endoscope has not turned up yet.
I have purchased Quickstep Paso (click LVP from B&Q), The flooring guy suggested that for underlay we may be better off using the green wood fibre board as underlay and could help a little with cold coming through? I have just read on the fibreboard description though "Recommended to use in conjunction with vapour barrier polythene as a damp proof membrane. Not suitable for use with LVT (luxury vinyl tiles/flooring)" so guessing this not right for the job
I also previously emailed an insulation website for advice who have mentioned that this type of product may suit better?
https://www.insulationsuperstore.co...-acoustic-floor-underlay-12m-x-1m-x-10mm.html
I have had a look but dont think this would work ether as would be to spongey and would not support the joints of the clicks.
I think I will probably just end up going with Quickstep transit underlay.
