Imagine a flat until inflated air bladder, around 330mm x 740mm, onto which a caravan wheel is driven, then you inflate the bladder to raise that wheel to get the caravan side to side level. Assume that caravan weighs 1400Kg and so the bladder has to raise half of that 700Kg and is a single axle, just two wheels on the road. Question is - how much pressure is needed in the bladder to raise that wheel off the ground. The bladder is rated for a maximum pressure of 30 psi / 2bar.
