Unknown screw type- pls help ID!
8 Sep 2021
Hi there,
I came across a type of screw that I’m not familiar with. It’s to attach an arm test to an old chair.
The screw it’s self is attached to the arm but there is another part which goes underneath (that which I’m holding in photo) which has the corresponding thread inside the hollow barrel.
Any idea how to find a replacement and what it’s called so I can search for it?
Thanks!
Tom
Binder screw. What size is the thread? Can the head of the replacement binder screw be bigger than the old one? Have you lost one presumably?
Sleeve nut.
Most often used in door handles
You will find lots on Ebay
Sometimes called bed nuts or furniture nuts
The male part is a screw, the female part is a nut.
Example
Steel ones are stronger
