The short downspout from the lower bay roof is blocked. Evidence: water build-up and evident gunk at the opening of the pipe.
In this Victorian Terraced house, the pipe goes under the garden and exits onto the pavement. From out on the pavement, I have pushed five metres of drain rods in with no blockage, so the underground leg seems clear; it is just the vertical that seems blocked - or the intermediary bit at the bottom, which also turns.
The only thing is - due to the upper pipe dog-leg/kink, it's not possible to shove a straight poker down...
So what should I be thinking of using to unclog it? Will those flexi things with handles on the end (I believe they're called "augers") do the job, or are they mostly for internal pipes? https://www.amazon.co.uk/Amtech-S18...nsparent/dp/B01LYX9RRV/ref=asc_df_B01LYX9RRV/
I'm loathe to try loosening the dog-leg; we're talking very old ironwork here.
I'm also loathe to jet wash it, as the wall is newly painted... though this may happen with an auger, too.
