Gap between bay and sash window frame, paint first or seal first?
30 Aug 2010
London
I am redecorating my wooden sash windows. They need repainting obs and the gap needs filling. I'm thinking of using sika mortar fix or a sand/cement mix.
What's best, paint the windows first and then seal or the other way around?
Don't know the sika. I'd use troupret masonry powder filler.
Are they old sash windows?
Coverstain will work well to prime then maybe bedec barn paint to top off.
Could use bullseye123 to prime as the waterbased option. Depends if you want to stain block and fill a bit. Coverstain will de nib smooth with 320 grade sanding.
So many options tbh.
I can get the Troupret masonry powder filler locally so that is easy.
These hardwood sash windows are 3 years old.
No need to stain-block. I will use a water-based primer, an undercoat, and Weathershield satin final coat unless you think it is not advisable.
Whats a better way, fill gap first and then paint, or the other way round?
I use clear solvent primer preserver on wood then fill.
You have to wait a week or more before painting over (read data sheet online for guide) but you can carry on and fill.
The primer preserver will get right in the wood protecting that wood.
Some would prime first using waterbased primer but I prefer to use the solvent primer preserver. Lash it in as easy to use. Won't matter on masonry.
Normal to prime wood before fitting to seal
Re paint.
Whatever you think. Lots out there.
Re paint.
Thanks. Sorry if my question was confusing. I meant to ask about filling the gap between the bay and the window frame first and then paint the the windows, or the other way round? Does it matter?
The wooden window/sashes don't need filling.the wood is as good as new although the preserver will prolong its life I'm sure.
I'd prime with undercoat or use the primer preserver before filling against the wood. To protect.. Is that what you wanted to know
