- Joined
- 2 Feb 2023
- Messages
- 10
- Reaction score
- 0
- Country
Hi guys,i have a problem with my car where it doesn't start and then after few seconds it says "motor system failure"(it says it in german "motor system fehler" but its the same thing.The problem occured today after i tried to inflate my tire with a tire compressor yesterday,i had problems with the in car ligther 12v connector,it seemed that it stopped working a while ago but i still tried the tire compressor,my car battery was also weak for the past few months being that it is cold weather,i had to jump start it 2 times during this winter months already.Does it say "motor system failure" if the car battery is dead or when something else is gone bad as well?If so,i didn't notice it the last time my battery was empty.All the car does now when i try to turn it on is everything on the dashboard starts flickering and then after few seconds i get the "motor system failure" message,the car crancks but really weak,so what should i try first,maybe jump start it?or disconnect the battery connectors and leave it for a while then reconnect,could it by that the tire compressor messed up some electrical components and the car is "confused",last night it wasn't that cold that the battery would die just like that.Any advice or help would be much appreciated
