Hi
I found a shower tray to buy, checked the waste and bathroom joist, I have this problem:
The tray has a linear waste, dimension of the assembly under tray is 120mm deep and 350mm long. This waste runs along exactly on a joist , I guess needs a slightly bigger cut probably 140mm deep and 370mm long. Joists are 200mm deep, is this safe/possible as will weaken the joist? It is the first joist running along outside wall. The notch will be 520mm away from one end of the joist, the whole length of joist is 2400mm.
