- Joined
- 7 Sep 2022
- Messages
- 4,931
- Reaction score
- 1,437
- Country
I've an issue with a car battery being flattened seemingly at random, and suspicions that the charging circuit isn't operating effectively. Everything checks out whenever anyone looks at it; charging voltage with engine running is 14.5, parasitic draw is 20mA with engine off, so why the battery only registers as 25% full or less after a long run, and sporadically is found to be dead (8v) after being parked for a couple of days is currently a mystery
I want to get a track of voltage and of current drawn/taken by the battery over time so I can see if it's just a charging prob or if there is some occasional freak high drain when the car is off so I can start looking at possible causes..
But I've no idea what kind of kit could reasonably cheaply monitor these things and keep a regular history - in particular an ammeter that can pass and monitor the many hundreds of amps a 2.0 diesel requires for starting will likely be the tricky part..?
Dont mind a bit of DIY, build it myself with a raspberry pi, arduino etc but if there's something off the shelf for a hundred quid, great
