Just after some advice please.
A couple of days I had my central heating drained/cleaned.
Next morning the boiler fired up to heat the water (conventional vented system) and theres lots of sloshing noises coming from the boiler, boiler cuts out after 5 mins then starts back up and on it goes trying to heat the water.
I turned on heating, checked the rads no air when bled , checked pump next to cylinder again no airl came out so all good.
Boiler still making lots of sloshing noises so I expect it's air trapped but don't know how to get it out.
I noticed above the boiler on the flow side there is a drain off valve, if I cracked this open would it expel the air ?
The boiler has worked fine up until now it is old it's a potterton prima f50
Any advice anyone !
Any advice anyone !
