Evening all
We're in the process of speaking to plumbers about boiler upgrades. Would like to post here and see what others might opt for in terms of a good solution
House built in 96, 3 bed detached, approx 10 rads. Heat only boiler (from build we believe) located in kitchen. Gas meter opposite side of house next to front door, water cylinder in airing cupboard on landing. Cold feed so no water tank in loft. Heating requires the hot water on at the same time
A chap came over today and started to recommend an upgraded heat only boiler until he saw that the water cylinder is as old as the house and likely needs replacing soonish, so not as cheap as thought. He then said a combi might be best bet and look to move the boiler where the cylinder is
There are just 2 of us but we are planning ahead.
What would folks recommend.. upgrade heat only and cylinder or go for a combi? Waiting on some quotes but what would likely be the cheaper solution?
