Current electric shower and toilet are fed from mains supply. Pressure is terrible (have had plumbers and Thames Water round - no dice), so I've been advised I could try an electric shower with built-in pump that runs from the CWS instead (example).
However, I'm not able to get a new pipe into the bathroom. So if I go for it, both the shower and the toilet would need to be fed from the CWS. Bathroom and CWS cupboards are on the same floor (CWS at high level in spare room cupboard).
Is this likely to present any issues? Some thoughts I had:
1) Would there be an issue filling the toilet cistern from the CWS?
2) Would there be issues if the toilet is flushed at the same time as the shower is being run?
3) The two existing outlets from the CWS run to a salamander pump (for cold water), or to the vented hot water cylinder. Is taking the feed off one of those for the shower a bad idea (i.e will I need another hole in the CWS for a separate outlet to the shower/toilet)?
I do not plan on doing this myself, but working out whether it's feasible before getting a plumber in to take a look!
Chris
Chris
