Hi All, i have a Quick question with regards to a secondary return. I am in the middle of installing an ASHP with a Heat Geek high performance unvented cylinder.
I have a question with regards to where to join the secondary return.
1. Directly into the cylinder
2. Into the Hot water run close to the cylinder?
The reason for asking is because I could imagine that going directly into the cylinder Would cause more mixing and therefore reducing stratification in the cylinder.
I have 28mm cold water mains into the cylinder and was planning on using a 15mm pipe for 7m secondary loop. I presume 15mm is sufficient?
Thanks for any help.
