I have an Vaillant ecotec 831 combi boiler that just has standard on off controls for radiators and UFH with a zone valve. It was installed around 2013 and the UFH added later.
Is it possible to install a controller via ebus that would allow weather compensation?
Would a vaillant controller be best? I see TADO and Drayton do some ebus controllers?
Would it be possible to set the flow rate of the UFH to lower than the radiator flow temp? Currently the boiler doesn't know the difference and probably uses up a lot more gas !
Thanks.
Thanks.
