- Joined
- 24 Jul 2024
- Messages
- 11
- Reaction score
- 1
- Country
Vented system.
I was installing a new sink at the weekend and had to drain our cold water storage tank and hot water cylinder to be able to work with the pipes as no service valves previously and gate valves from CWST have all seized.
When finished I turned mains back on and tanks refilled but our CWST fed taps (bathroom taps, bath, ensuite and downstairs cloakroom) cold supply only did not flow. Hot water working perfectly. I think it was likely an air lock so I got a wet vac and have sucked air out of all the affected cold water taps. This has worked to an extent but there is still poor flow, worse than previous to me working, and when I run the bath cold tap and try and run the basin cold tap, the basin cold stops (as does refilling of the toilet cistern) while the bath continues, albeit poorly. When I stop the bath cold, the basin will start working again.
I've tried repeating the wet vac a few times but doesn't seem to be improving things any further.
Can you offer any further advice?
Thank you!
Thank you!
