How to stop leak for Bosch dishwasher matrix / heat exchanger
30 Aug 2024
United States
Hi everyone. I have a Bosch Super Silence model that has been leaking on the inside through the left side wall (through the large plastic screw or whatever it's called).
Symptoms:
- water leaks in and accumulates while the dishwasher is not in use. In one day, the water level is enough to spill on the floor.
- the plastic tank / heat exchanger / matrix in the photo slowly fills up to the top and then the leaking starts inside the dishwasher.
Any ideas how to stop the leakage?
Symptoms:
Replace the solenoid valve, at the water input connection, which is passing water. Until then, isolate the supply, when not in use..
