Hi All,
1975 era house with a mix of Concrete block and Cinder block internal walls which I am certain were cement rendered and skim plastered originally. I have removed a lot of built in wardrobes and also cut many chases for wiring and have been filling chases to circa 2mm sub surface with Bonding plaster ready for a multi top coat. Where the wardrobes were removed, there was 2x3 battens nailed to the block work prior to rendering, so I have floor to ceiling 3 and 4" wide gaps in the render. I also have bricked some windows up a few courses.
For these larger areas (which includes a corner), is there a convention on doing them in cement render rather than Bonding plaster similar to original or Bonding plaster like usually done for chases? Similarly over 2 courses of bricks, would you normally build this out in render for strength?
All thoughts appreciated!
