- Joined
- 3 May 2021
- Messages
- 62
- Reaction score
- 4
- Country
I am trying to stop my landing floorboards from squeaking.
When I first moved in I put some screws next to the nails in the floorboard.
It improves the situation that they are still extremely squeaky (much more than anywhere else in the house).
I considered trying to replace a couple of the floorboards themselves in case they have become a little bit misshapen, bit as the floorboards are all tongue and groove, I would potentially have to replace the whole lot.
I tried to loosen and peer under one of the floorboards today to see if I could identify where the pipes are. To do this I removed some of the screws that I put in originally and they came out relatively easy (even a cheap electric screwdriver could undo them). I wondered therefore if these screws went deep enough into the joists.
I have some 45 mm floor tite screws which I thought might do the job.
However, whenever I have used the screws they don't go into the floor flush, always protruding by approximately one centimeter. Even if I drill a pilot hole or try and forcing in with a manual screwdriver they won't budge and go flush. I've also read online that these do not need pilot holes anyway!
Any ideas why these screws are not going in for me? This was the situation in more than one room so it's not just the particular joist that I was trying today.
Also whilst you're here if there's any other hints and tips other than ripping it all up, that would be great
