- Joined
- 17 Oct 2005
- Messages
- 210
- Reaction score
- 3
- Country
This is my current aerjec. The pipe you see leading out the top of it is the combined feed and vent. This is the pipe that goes into the bottom of the F&E tank.
There is no other vent pipe or indeed any pipe that goes into the loft, except the cold main, to refill the tank.
nah, that dont sound right at all then to me - I would branch off your pipe at the bottom of the tank to another pipe going above your F&E tank and bent over the top to make a proper combined F&E system then ... plus also safer if boiler should ever overheat, the water then will just boil up the vent pipe, go over the curve, into the F&E tank and fill that up and then exit outside the property by pipe just underneath the eaves and out into the back yard
or if you want to keep your air seperator thingy you could plumb like this:
