Finally got it right after many years of trying and having had advice from son who did Exeter Catering college:-
1. Assuming you can afford it always buy Sirloin or Topside which is at least 28 days old. Around a kilo is best but adjust times a bit if larger.
2. Bung in roasting tin and pour over 1/2 glass of red leave at room temperature overnight.
3 Get oven up to 220 before putting it in for 20 mins then reduce temperature to 180 and cover the tin to help keep moisture in.
4. After another 25 mins check temperature with a meat thermometer (not essential but gives a more certain result). Hopefully the inner temperature should now be 55 -58 and you can take it out to "rest" on a decent plate for at least ten mins.
The result will be what is known as medium rare, tender and juicy,Yum!
Yes I have done "well done" in the past but it was always dry and tough and professional chefs never do it.
