Reform UK's plans to obstruct green energy projects in Lincolnshire put at risk almost £1bn in local investment and more than 12,000 jobs, ...thats the project they want to block btw.
Buildings are more expensive and smaller.I must admit, I'm not convinced about solar farms of this scale. I think it works better for the PV to be installed on a building and provide power without the need for huge pilon infrastructure and loss of farm land
If you don't own the property then you've got to have some agreement with the property owner if you want to install PV on it.The benefit of installing PV solar on the roof is that it doesn't take up large amounts of land. What are the legal concerns?
5% of homes now have solar installed. Imagine what 25% could do. Yes it costs more, but it's the right approach. The roof is wasted space, our country needs farm land for farms, or houses etc.If you don't own the property then you've got to have some agreement with the property owner if you want to install PV on it.
Roof mounted PV is great, but it's also the most expensive way to do PV.
Imagine you're the company trying to build this 50MW array and you had to find 10,000 domestic properties that'll let you rent their rooves for 20 years and not get to use any of the electricity their panels generate.
Im with you on rooftop PV, but Rooftop power isn't enough and will never be enough. That JLR plant is a good example, they out in a huge array and it's only a small fraction of their power drawn. They need more.5% of homes now have solar installed. Imagine what 25% could do. Yes it costs more, but it's the right approach. The roof is wasted space, our country needs farm land for farms, or houses etc.
I installed my first solar back when you could get 63p per KW generated. Back then a 2.4kw system was costing £15k. Now you can get double that for half. The business case is sound and it avoids using up valuable land. The alternative is to have all this farm land locked out for 40 years.
it's nimbys, it's always nimbys.The growth in Solar PV annually would power 2 JLRs. This is a tech, that improves year on year, I'm not convinced we need to go much faster than we are, otherwise you end up needing to manage the end of life and replacement of all these legacy units.
Anyway - the OP was arguing that Reform's links to fossil fuel are the reason they are trying to block the solar farms. Other sources suggest its concern from locals at the scale.
I think they have a 20 year life, based on my own installs.The panels look like they'll last 30-40 years at the moment. Retirements are a way off yet
PV growth is huge, 600GW of panels last year. Most of it in China. We're pretty slow at large scale PV and Grid batteries.
They used to have 20 years warranty but they've been progressively increased it. Now even cheap ones have 25-30 years under warranty.I think they have a 20 year life, based on my own installs.
