- Joined
- 2 Feb 2022
- Messages
- 51
- Reaction score
- 2
- Country
A week ago my lodger told me the bathroom sink was draining slowly. I put some caustic soda down it and rinsed with a kettle. It made a few glugs, spat out some dirt and now it's completely blocked - no drainage at all. I tried using a snake, but it seems to be a build-up of dirt rather than anything the snake can grab onto, so that didn't work either.
I've had a plumber over and they tried a plunger and a hoover, but neither worked - apparently the sink is vented and the vents are right up against the wall, so they couldn't make a proper vacuum. They didn't want to use pressure machinery because it's a very old lead pipe and apparently that might burst it. I've been quoted almost £5k to have the pipe removed and replaced.
Before I consider that, is there any reason why I can't/shouldn't just saw off a section of the pipe below the u-bend, use some kind of big poking device to try and clear the blockage, then replace the missing section with a £10 plastic pipe?
Photos of:
1. Where the pipe connects to the basin
2. The U-bend
3. The bit of pipe I'd cut through
4. The pipe on the other side of the bath panel
Photos of:
2. The U-bend
