How do you know the factory didn't paint it then?
Oh I think it'll be pretty obvious...
Go on then, explain.Oh I think it'll be pretty obvious...![]()
The first page shows various coloured bulbs, which one did I paint?Because in order to get its type approval (and thus, it's "e" or "E" mark), It will have to go through these tests:
The minute you make any modification to it, you make it different to what was tested, so whatever approval it held, is no longer valid.
Dobbing some random shade of amber paint on it, won't look like a factory-applied coating any more than your efforts at painting the rest of the car did.
None of 'em but whatever anyone says, you’ll say they were wrong anyway.The first page shows various coloured bulbs, which one did I paint?
You are wrong. How do you know I didn't paint one?None of 'em but whatever anyone says, you’ll say they were wrong anyway.
No runs in the paint, no over spray on the metal bits, no 30 page thread on painting just one bulb. Easy.You are wrong. How do you know I didn't paint one?
It just means I am skilled at painting bulbs. So, you can't tell which I painted?No runs in the paint, no over spray on the metal bits, no 30 page thread on painting just one bulb. Easy.
Don't try to change the subject. Which one did I paint, o'investigtor?You really think, that if it came to an accident big enough for the investigators to be bothered about bulb colour, that they'd be fobbed-off with a low-res photo of the bulb from an internet forum???!![]()
Would they really check the shade of amber on a bulb even in the most serious of accidents? Chances are, the bulbs will be damaged or broken. What about a non-working bulb. Should we stop every 5 metres for a bulb check? What about checking all bulbs for 'compliance' when we first acquire a new car in case some master criminal has fitted a non compliant bulb sometime in the vehicles past. Same applies to every other part on the car. Brakes? Steering joints? Nah!I don't know whether you're a bit "hard of reading", "hard of thinking", or maybe both, but as I've already said, in an accident serious enough to warrant such an investigation, no investigator would ask you to e-mail them a low-res photo and make the call based on that. They'd pull the bulb out of the car, stick it on a test rig and see if it matched the characteristics of the one in the test report. I know you're pretty naive but nobody would just "look" at it (never mind a photo of it!) and take that decision.
The typical small shop that the insurer use for assessing accident damage/compliance wouldn't have this rig, though. Since there is E-mark on the bulb, they'd pass it without a second thought.I don't know whether you're a bit "hard of reading", "hard of thinking", or maybe both, but as I've already said, in an accident serious enough to warrant such an investigation, no investigator would ask you to e-mail them a low-res photo and make the call based on that. They'd pull the bulb out of the car, stick it on a test rig and see if it matched the characteristics of the one in the test report. I know you're pretty naive but nobody would just "look" at it (never mind a photo of it!) and take that decision.
