When I'm pi$$ed I see double if that helps....
Indeed a mere 65 posts ago I said the same thingI definitely see two fingers.
So do I.
As I began - how could you not?
It's not intuitive but you are not quite correct, please note I'm gently saying there is a slight error in your statement rather than saying you are wrong.I agree with that, assuming the doubled object, is nearer, or further away, than the object you are focussed upon. If the distance from the viewer is similar, then only one version of the none focussed upon object will be seen
OK. This is interesting - and seems a bit reminiscent of autostereograms ...I definitely see two fingers.
And they are in the places where I see one finger when I close one eye, i.e. when I close an eye, neither finger moves, but one disappears.
So the expected test result is that with my dominant eye open I see my finger aligned with the distant object, and with the other eye open I see it displaced to one side. That all "works" as expected.
It's just that with both eyes open I see two fingers - one aligned, the other displaced.
O M G were we right all along?OK. This is interesting - and seems a bit reminiscent of autostereograms ...
It continues to be the case that whenever I just 'do' as I have described, with both eyes open I only see one finger.
However, I've just been playing and have at long last managed to see two fingers - but that took a long time of staring roughly at the distant object, moving my eyes around a bit and constantly 'changing my focus in and out'. After what must have been at least 5 minutes of doing that, rather like an autostereogram, a second finger, somewhat more 'ghostly', suddenly 'jumped out at me', to the dominant side of the one I had aligned with the distant object. It then behaved as you describe above - "with my dominant eye open I see my finger aligned with the distant object, and with the other eye open I see it displaced to one side" (which is what is expected of the test).
Why a lot of people seem to see the second finger so easily/quickly, whereas it takes me a lot of effort remains a mystery, but perhaps that is 'just me'!
I subsequently managed to do the same thing again, and this time aligned the 'second' ('more ghostly') finger with the distant object, but it again was the case that "with my dominant eye open I see my finger aligned with the distant object, and with the other eye open I see it displaced to one side", the only difference being that the displacement was this time in the non-dominant, rather than the dominant, direction.
This may possibly explain the problem I've been struggling with. In the distant past, I must have got many hundreds, if not more, people to undertake this test, but without (that I recall!) being aware of the potential problem which people have raised in this discussion. However, if they did see two fingers, if what I asked them (I really don't remember) was to tell me which eye they could close leaving the finger still aligned with the distant object, it would not have mattered which of the fingers they had initially aligned with the distant object. I really can't remember (we're talking a good few decades ago), but if any asked me 'which finger they should align with the distant object', maybe I told them that it didn't matter?
So, I think we (or, at least, I) have made a bit of progress about this issue!
The test itself (involving closing eyes alternately) is actually irrelevant, since the seemingly anomalous situation you are describing arises before one gets that far!
The "precise detail" of the process prior to the actual test is incredibly simple, and has already been described several times ...
• Look at/focus on/concentrate on some 'distant' object (anything over a couple of metres or so away will do).
• Extend one arm straight in front of you with one finger 'sticking up'.
• Whilst still looking/focussing/concentrating on the distant object, move that finger so that it is seen (in a slightly ghost-like fashion, since it''s out of focus) in front of the distant object.
That's it (prior to progressing to the 'actual test'). One should see just that one 'slightly ghost-like' finger, not two.
All true, but remembering that, as I had at the start, the two eyes will usually be pointing at the object at slightly different angles (i.e. not both inclined inwards by the same angle). However, as you go on to say, the important issues are nothing to do with 'focus', per se, but, rather, where the image of the objects appears on the retinas.It has everything to do with it (as regards human binoccular vision), you are asking me to focus on a distant object, which means my lenses are hopefully adjusting to achieve that focus and additionally the eyeballs are hopefully directed such that their central fields of view are coincident on the target object.
We're not talking about something 'dumb' like photography. The whole concept of binocular vision obviously involves the brain receiving information from two eyes, with the position of the object on the retina being slightly different for the two eyes, and processing those two sets of information to produce a single perceived image.Now for any object at a different distance (and to a lesser noticable extent off to one side at the same distance of the focal point); the central fields of view of the eyeballs are not coincident on the additional object. Therefore the additional object will be percieved to be either 2 objects or one object in 2 different places.
That could well be the case (and maybe 'an explanation' in the case of myself), particularly given that, as I have said, I am extremely strongly right-handed (to the extent of not being able to do much at all with my left hand).In that case, my best explanation is that the dominant eye of some of us, is not quite as dominant as yours would seem to be.
Fair enough. I obviously can't argue with what you are telling me about yourself, any more than you can (should!) argue about what I';m telling you about myself. We are clearly different!Sorry John, but while ever maintaining my focus, on that distant object, with both eyes open, I see what I would expect to see - two fingers, and until I move my focus to that finger, when it becomes one.
Yes agreed, the brain does sort out lots of the errors between the binocular detection. In my edited #153 the description would equally apply if the focal point were reversed with the additional point (ie looking sideways at something) but I think nit picking is occuring now.All true, but remembering that, as I had at the start, the two eyes will usually be pointing at the object at slightly different angles (i.e. not both inclined inwards by the same angle). However, as you go on to say, the important issues are nothing to do with 'focus', per se, but, rather, where the image of the objects appears on the retinas.
Hence, it is not necessarily the case that one will perceive two objects in the situation you describe - since the brain is used to having to combine two slightly different sets of information to create a single perceived image. Were that not the case, we would see almost everything 'double', unless it was sufficiently far away that the images on the two retinas were essentially identical.
Perhaps it wasn't described to them properlyThat could well be the case (and maybe 'an explanation' in the case of myself), particularly given that, as I have said, I am extremely strongly right-handed (to the extent of not being able to do much at all with my left hand).
However, it is not really an explanation of why I don't recall any 'problems' with the hundreds of people I have got to do 'the test' in the past (although I've offered some suggestions as to why it may be that there were not 'problems'). I suppose it could be 'failing memory' on my part![]()
See my edited #153.No I am not, the seeing of the doubled up object, is simply because the angle between the two eyes, doesn't converge at the correct distance. If the distance matches, there will only be one object seen.
See my edited #153.
