Help me identify these bushes please
18 Apr 2025
Hi
(Thanks for previous help with plants for border-on the case with that)
We’ve had two bushes on t’other side of garden for years. Never done any maintenance. (explaining why one is now too close to conservatory)
You will also see the stem of another bush protruding from the bush on the right. Can you tell me what that is and whether I should remove it and its root system?
Many thanks again.
Isnt there and old saying along the lines of .. there's many a slip twixt bush and lip (y) Oh no, sorry, that should be cup and lip :oops::LOL:
Regarding that intruding bush .. from the photo it could be a species of NZ hard wood shrub of which the name escapes me. My advice if remove it and cut it up straight away because within a few days the cuttings harden right off.
I don't know what it is. The stem looks like alder or hazel but the leaves look like lilac. In any case, it looks like it's on a trajectory where it will tower over your conservatory and you probably don't want that, so get rid.
If it is a lilac it could be pruned down to a more manageable size.
Hi again
Decided to go for the nuclear option. The problem is the intruder seems to have already formed a wide and hard root. It’s also adjacent to the hypericum roots, so don’t want to damage those.
How would you proceed from here?
Thanjs
I would just leave it and see if it comes back. Some plants [eg alder and hazel] will send up lots of new shoots after being pruned hard, some will be mortally wounded.
The last two images taken of the remaining stem (in foreground) after cutting it. V difficult to get any purchase on my various spades to isolate and remove the intruder’s roots.
On closer inspection, leaves v similar shape to those of lilac. However mine have a serrated edge, which is more suggestive of alder or hazel? Attached images are front of back of our leaves.
To kill a stump, brush concentrated Glyphosate on the freshly cut stump while it is wet with sap. Within 5 minutes of cutting is not too soon.
SBK brushwork killer can also be used.
Spirea on the left, yellow flowered bush on right as others have said is Rose of Sharon (hypericum)
