Need advice for a suitable motion detector replacement
30 Jul 2013
London
Hello
This wall mounted motion detector is broken and I would like to have it replaced (see attached picture).
This detector doesn’t have light integrated, instead it will just switch on / off bigger (non LED) lights it is connected to.
I am looking online for a replacement but think the ones I am looking at have LED light integrated in the product, meaning they do the lightning ? Example below:
Anyone can suggest a suitable replacement please ? Ideally I just need the detector itself, it can be disconnected from the black box above it where the electric wires are (see second picture), so I would rather not replace the entire thing which would be a bigger job as well.
Many thanks
@ETAF Thanks, but do you think those would fit into the black box I have please ? It looks like they come integrated with it, meaning I will need to replace everything. As for what it switched on / off, two of those old school lamps at the door enterance
Are the mods/administrators right?
Am I the only one getting this with Screwfix links?
nope - been getting it all day
I don't know. It nearly always works fine for me.
It may depend on whether you have third party links enabled in your browser, or something similar.
Also the Screwfix (etc) site may not like it if it can't tell you're human, for example if you're using a VPN.
If I use a different browser I get different results.
You could try highlighting the link., right click, and "Search using... (google, etc)"
The query has been passed to the site owner.
- From one mod of many. -
But it says “The sensor does not work with fluorescent lamps.”
As per my original post, mine isn’t LED
